EZVPN connecting to PIX515-Cisco877 router VPN
Feb 23rd, 2007
The EZVPN is working fine to the PIX network but can't connect to the 877 Lan.
Network A -----------Network B
Public 83.xxx Public 86.xxx
LAN 172.16.30.0 LAN 10.0.0.0
EZVPN 172.16.100.0
EZVPN connecting to A but can't access the second VPN tunnel.
I have checked the forums and found similar setups but can't find the issue with this one
ggilbert Fri, 02/23/2007 - 09:57
Are you doing "client - Mode" or "Network Extension Mode"
If you are doing client mode what is the IP address assigned to the router when it gets connected.
sh cry ipsec sa - from the router side would help to see if there is an ipsec sa created for those networks.
Gilbert
Rate it, if this helps.
