UK FXO problems
Peter Cresswell
Level 5
Level 5
I am having problems with an FXO card in the UK (BT is the telco). Could anyone please post a working Voice-port config for a single analogue BT line connected to an FXO port?
I have tried numerous settings and can't get it to work. When I make an outgoing call it open the line, supposedly dials the number but all i hear is the tone you would get if you dialed in incorrect number.
Many thanks,
Peter
mchandak
Level 7
Level 7
what is the dial-peer you are using and the number being dialed.
Aaron Harrison
Hi Peter
Did you get this sorted?
If not post your dial-peer configs and we'll take a look.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
