Pix IOS 6.3(4) to 6.3(5)
Feb 23rd, 2007
I have to update PIX IOS 6.3(4) to 6.3(5).
Since I have PIX in my datacentre so how to update it than and what to keep in mind
vitripat Fri, 02/23/2007 - 09:50
The only thing you need ot make sure is save the configuration to flash before upgrading and save "show tech" output to TFTP server. Use following command-
write mem
To save the configuration, you can just copy the show tech output to a text file or use "write net" command.
After that there wont be any issues after upgrade. You can refer to following link on how to upgrade:
http://www.cisco.com/warp/public/110/upgrade.shtml#upgrade511
Hope this helps.
Vibhor.
