Adertise loopback address
Feb 23rd, 2007
Hi all,
I want to advertise loopback address with its subnet mask in ospf. One way is by making the loopback point-to-point.
ex:
RTA(config)#int lo0
RTA(config-if)#ip ospf point-to-point
Is there any other way?
Overall Rating: 3 (1 ratings)
sundar.palaniappan Fri, 02/23/2007 - 11:14
Yes, you can redistribute the connected network(s) into OSPF and the loopback will be advertised with the actual subnet mask configured on the interface. You can use the 'redistribute-connected' command with a route-map to include the loopback and whatever connected interfaces you desire to advertise via OSPF.
Sundar
