Network Management ani.log files
Feb 23rd, 2007
ani.log files are full and are not being moved to the ani.log backup file. What is the cause and fix for this issue. Can i delete to contents in the ani.log file.
Joe Clarke Fri, 02/23/2007 - 11:49
Okay. That file can be safely truncated provided a Campus Data Collection is not currently running. To truncate the file, you can either configure /opt/CSCOpx/bin/logrot.pl or just do:
cat /dev/null > /var/adm/CSCOpx/log/ani.log
You should also check under Campus Manager > Admin > Campus Data Collection > Debugging Settings to make sure all debug is turned off if you are not currently trying to debug a problem.
All that said, this file should automatically be archived the next time a Data Collection is run.
