Pat not working on 806 w/cable modem
I am hoping someone here can help, I have a cisco 806 dual ethernet between my LAN and my cable modem, for some reason i can not get the PAT to work, the only thing i can ever get in the show ip nat translations is the wan interface from me pinging from the routers console, it has not recognized anything on the lan and translated it yet. My config is below,
! Last configuration change at 02:02:56 UTC Fri Feb 23 2007
! NVRAM config last updated at 01:38:34 UTC Fri Feb 23 2007
version 12.2
no service pad
hostname 806Gate
no logging console
enable secret ***
enable password ********
username **** privilege 15 password 0 ********
ip subnet-zero
no ip routing
ip dhcp excluded-address 10.10.10.1
ip dhcp pool Clients
network 10.10.10.0 255.255.255.0
dns-server 65.*.*.70
default-router 10.10.10.1
interface Ethernet0
description LAN
ip address 10.10.10.1 255.255.255.0
ip nat inside
no ip route-cache
no ip mroute-cache
no cdp enable
interface Ethernet1
description Internet
ip address dhcp client-id Ethernet1 hostname 806Gate
ip nat outside
no ip route-cache
no ip mroute-cache
no cdp enable
ip nat inside source list 1 interface Ethernet1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet1
ip http server
ip http authentication local
access-list 1 permit 10.10.10.0 0.0.0.255
no cdp run
line con 0
exec-timeout 0 0
stopbits 1
line vty 0 3
exec-timeout 0 0
password ******
login local
length 0
transport input telnet
scheduler max-task-time 5000
ntp clock-period 17176398
ntp server 192.5.41.209
end
Thanks for any help....
M@
