WPA2-PSK
Feb 23rd, 2007
Greetings -
I currently have a Cisco AIR-AP1231G-A-K9 that is running IOS version 12.3(8)JEA1. I am trying to setup WPA2 "Personal" (WPA2-PSK) with a client running Windows XP SP2. The WLAN Nic is a Cisco a/b/g PCMCIA, driver version 2.5.0.22. I have configured the PSK on both the AP and the client and verified that I did not make a typing mistake. I have installed the Microsoft WPA2 hotfix to see if that was causing the problem but it is not. The actual problem is that the client says it's "Authenticated" but will not allow any traffic to pass through. Whenever I created an SSID NOT using WPA2-PSK, the client can ge an IP address and things function normally. Here is the current AP configuration:
sh run
Building configuration...
Current configuration : 4170 bytes
version 12.3
no service pad
service password-encryption
hostname AP1
enable secret ****
ip subnet-zero
no aaa new-model
dot11 vlan-name Joes-VLANofFUN vlan 237
dot11 vlan-name Joes-VLANofFUN-PartII vlan 238
dot11 ssid -=b0Gg$=-
vlan 237
authentication open
--More-- authentication key-management wpa
wpa-psk ascii ****
username Cisco password ****
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 237 mode ciphers aes-ccm
ssid -=b0Gg$=-
--More-- speed basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
no power client local
power client 50
power local cck 50
power local ofdm 30
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.237
encapsulation dot1Q 237
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
no cdp enable
bridge-group 237
bridge-group 237 subscriber-loop-control
bridge-group 237 block-unknown-source
--More-- no bridge-group 237 source-learning
no bridge-group 237 unicast-flooding
bridge-group 237 spanning-disabled
interface FastEthernet0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
speed 100
full-duplex
hold-queue 160 in
interface FastEthernet0.237
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
no cdp enable
bridge-group 237
--More-- bridge-group 237 subscriber-loop-control
interface FastEthernet0.238
encapsulation dot1Q 238 native
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
bridge-group 1
interface BVI1
ip address 10.238.1.100 255.255.0.0
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
--More-- ip default-gateway 10.238.1.10
no ip http server
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
privilege level 15
logging synchronous
line vty 0 4
login local
end
I have tried upgrading the WLAN NIC drivers to the latest version (3.5 I believe) but it does not help. If I run the troubleshooting task of the Aironet Desktop Utility is sasys that the Authentication tests failed, even though the status shows me as "Authenticated". Perhaps there is something in the above config that I am missing.
Any help would be greatly appreciated.
Joe
scottmac Fri, 02/23/2007 - 16:39
Check the hardware version of your AP radio(S).
Earlier versions (ending in "20") do not support AES (used for WPA2 / 802.11i).
You should have at least a "Radio AIR-MP31G " for your 802.11G and "Radio AIR-RM21A" for your 802.11a radio.
THe (probably) easiest way to check this is the Web GUI ... go to INterfaces, select each band, then the "Detailed Status" tab.
If your radios are older than this, the CLI and GUI will accept your configuration for WPA2/802.11i, but will not operate in that mode (and usually fail).
Either radio is independently upgradeable for ~US$100.00 through someplace like www.cdw.com.
Good Luck
Scott
Trending Topics - Security & Network
