power injector link propagation
Feb 23rd, 2007
We are using catalyst 3550 100BaseFX and fiber power injector to connect to AP1240.
We have also configured station-role root fallback shutdown so when ethernet goes down it also does Radio interface but this is not working.
Does the power injector propagate link loss to AP ?
Answers will be more than appreciated
sbilgi Thu, 03/01/2007 - 07:35
What is it happening exactly once the Ethernet interface goes down?. Because, with "fallback shutdown" command,
the access point should shutdown when the primary Ethernet interface is not functional. If this is not happening then tell me what is exactly happening and also, send me your output of show run
snofrar Tue, 03/06/2007 - 15:10
Actually, the ap ethernet never goes down because when the switch goes down there is not link loss propagation from its interface (100BaseFX) to the ap ethernet interface (100BaseTX) through the transceiver.
We are planning to test HOT Standby using IAPP queries but although the stanby ap will detect the link loss, from the point of view of master ap it will look like that standby ap is down so we don't know how it will work... any suggestion ?
interface Dot11Radio1
no ip address
no ip route-cache
encryption vlan 721 mode ciphers tkip
ssid QSSQ
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
power local 17
power client 17
beacon period 98
no dot11 extension aironet
dot11 extension power native
interface Dot11Radio1.721
encapsulation dot1Q 721
no ip route-cache
bridge-group 255
bridge-group 255 subscriber-loop-control
bridge-group 255 block-unknown-source
no bridge-group 255 source-learning
no bridge-group 255 unicast-flooding
bridge-group 255 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
hold-queue 160 in
interface FastEthernet0.721
no ip route-cache
bridge-group 255
Thank you for your attention
ruben.montes Wed, 03/28/2007 - 02:23
I'm suffering the same problem... Have you found any solution?
Thanks in advance,
Ruben
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
