WLSE 1130 K9 ?
Feb 23rd, 2007
how do you reset password on the 1130 ?
rob.huffman Fri, 02/23/2007 - 17:32
Hi Tom,
Have you tried this method;
Changing Your Password
The user password is set when the user is created. Use the following procedure to change your password.
Note Your login determines whether you can use this option.
Procedure
Step 1 Select Admin (Tab) > My Profile > Change password.
Step 2 To change your password, enter a new password in the New Password and Re-enter New Password fields.
Step 3 Click Apply to save your changes or Reset to discard your changes.
From this WLSE doc;
http://www.cisco.com/en/US/products/sw/cscowork/ps3915/products_user_guide_chapter09186a0080364096.html#wp1446214
Hope this helps!
Rob
