Assigning STATIC IPs to remote clients from an ASA5510
Feb 23rd, 2007
I'm trying to setup a few clients out in the field that I want to connect in to the corporate using vpn. I want them to always get the same address so I can setuo DNS on the corporate lan how can I do this?
Kamal Malhotra Fri, 02/23/2007 - 13:27
Yes, you can do this. To configure this, using ASDM, follow these steps :
1. Goto Configuration > VPN > General > Users.
2. Slecet a user and click modify.
3. Goto VPN Policy tab.
4. On the bottom of the screen the option is to configure dedicated IP.
HTH,
Please rate if it helps.
Kamal
