02-24-2007 02:17 AM - edited 03-14-2019 08:11 PM
Hi Guru's..
I am getting this message in the BARS Logs, so could anyone tell me how can i slove this problem..
The version of CCM installed - CCM 4.2(1)has not been verified to function with BARS 4.0.9000. You should upgrade the BARS software to ensure complete compatibility otherwise you could experience data loss during restore.
02-24-2007 06:50 AM
Hi MS,
This error is telling you that BARS 4.0(9) is not compatible with CCM 4.2.1 You will need to upgrade BARS to a newer version;
For CCM 4.2.1 -
Minimum version - BARS 4.0(9)sr1
Recommended version - BARS 4.0(10 or 11)
BARS 4.0(11) Release notes;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_release_note09186a0080724990.html#wp36691
Hope this helps!
Rob
02-24-2007 07:04 AM
As Rob has mentioned, you need to be on 4.0(9)SR1 or above. I'd recommend going to the latest version 4.0(12). You can download it from http://www.cisco.com/cgi-bin/tablebuild.pl/cmva-3des. Make sure you read the Release Notes/Readme also
02-24-2007 04:51 PM
I'm running BARS Version 4.0.11 and I am getting 2 version errors in my backup job.
The version of CAR installed - CAR 4.1 has not been verified with BARS 4.0.11000.
and
The version os CER installed - CER 1.3 has not been verified to funcation with BARS 4.0.11000.
Are these legit errors or just cosmetic? 4.0.11 was the lastest version of BARS when I upgraded my system.
02-24-2007 05:39 PM
This is fixed in BARS 4.0(12).
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/prod_release_note09186a00807da736.html
AFAIK, this is cosmetic bug as well.
