Video Codec Basic question
Feb 24th, 2007
I am little bit confused, I have VT advantage A connected to an IP phone A with another IP phone B and VTA B.
When they are both IP phone in the same region, if i put the Video call to 50 Kbp, the video will still work between bot of them.
when i create a region and enable bandwidth for less than 384 between both location the call will be voice instead of video as there is not bandwidth enough.
I am confused, what is the bandwidth needed for the VTA and how can i limit it on the WAN using location.
Good day
ivillegas Thu, 03/01/2007 - 11:55
Around 380kbs could be fine with the video. I think you need to have QOS applied to the interface so that bandwidth issues can be overcome.
gajolly Mon, 03/12/2007 - 00:47
as mentioned in previous post 384 will be good enough however please take layer2 + layer3 headers in consideration
hth...
