Simulators for CCNP
Feb 24th, 2007
Does anybody have any good suggestions for the CCNP course or would it be better to get my hands on a few switches and routers. Currently studying the switching exam
Overall Rating: 3.7 (4 ratings)
hoogen_82 Sat, 02/24/2007 - 05:30
Well the real routers and switches is always good way to learn.
But if money is a concern at start try Boson's simulator. It helps to a certain extent but the real stuff is always good.
There is another one called dynamips. U need high end PC for this cause you can run routers on this one just like running a real router.
Hoogen
Do rate if i have helped :)
