VPN Tunnel stopped sending traffic
Answered Question
Feb 24th, 2007
One of our VPN tunnels stopped sending traffic.. IS there any way where we can reset the tunnel again since i know that there were no config changes done on the tunnel
Thx
Shyam
Correct Answer by kaachary about 9 years 7 months ago
Hi Shyam,
To clear the tunnel, you can do a :
On PIX :
clear cry isa sa
clear cry ipsec sa
On IOS :
clear cry isa
clear cry sa
HTH,
Rate if this helped !
-Kanishka
Overall Rating: 4 (1 ratings)
Correct Answer
kaachary Sat, 02/24/2007 - 05:44
Hi Shyam,
On PIX :
clear cry isa sa
clear cry ipsec sa
On IOS :
clear cry isa
clear cry sa
HTH,
-Kanishka
dondongamo Mon, 02/26/2007 - 01:17
Your answer is only applicable to a single tunnel. What if there are several tunnels and want to terminate specific tunnel w/o disturbing other live tunnels, is there any way we can point to specific SA id? or is it by way of clearing the specific vpn group? and what normally the time it takes to clear the SA id from the table and re-established the tunnel?
TIA
