Error copying flash
Feb 24th, 2007
Hello All,
I have a 3640 router with 128MB DRAM and 32MB FLASH. It is currently running IOS c3640-jk9o3s-mz.123-19.bin. I am trying to copy a new image into flash (c3640-ik9o3s-mz.124-7.bin) and receive the following output:
%Error copying flash:c3640-ik9o3s-mz.124-7.bin (No space left on device)
This is what I get when a show flash command is issued:
3640_1#sh flash
System flash directory:
File Length Name/status
1 25690048 c3640-ik9o3s-mz.124-7.bin [deleted]
[25690112 bytes used, 7340028 available, 33030140 total]
32768K bytes of processor board System flash (Read/Write)
How come the entire image does not fit into flash when there is enough room?
Thank you in advance.
hoogen_82 Sat, 02/24/2007 - 06:49
do a squeeze flash: command
Hoogen
Do rate if this helps :)
hoogen_82 Sat, 02/24/2007 - 07:13
the last step format your flash and then load the new image
hoogen
royalblues Sat, 02/24/2007 - 10:06
Mike,
1. Erase the contents of the flash
erase flash:
2. Squeeze flash contents
squeeze flash:
(remember not to reload your router when you erase the flash, otherwise the router would go to rommon mode and you have to do a disaster recovery)
3. Upload the new IOS
4. Reload once upload is successful
let us know how it goes
HTH, rate if it does
Narayan
MikeC5000 Sat, 02/24/2007 - 10:25
It did not work but thank you for the input. I still receive the same error message.
MikeC5000 Sat, 02/24/2007 - 14:14
I still receive the same error message at the same point in the copy. I executd the squeeze command and then ran a sh flash: and got this:
3640_1#sh flash
No files in System flash
[0 bytes used, 33030140 available, 33030140 total]
I have gotten this same output every time I erase the flash memory. It just continues to tank in the same exact spot. Thank you for your effort.
vaisharm Sun, 02/25/2007 - 04:12
Mike,
Please ensure that there are no files in the flash (not even marked deleted). Next, ensure that the laptop/workstation on which you have the tftp server does not go into standby mode and disbale the screen saver as well. Try a different tftp server.
http://tftpd32.jounin.net/download/tftpd32.302.zip
I have seen it work this way. Good luck!
Do let us know, how it goes.
- Vaibhav
MikeC5000 Sun, 02/25/2007 - 05:45
I tried this procedure 2 times and failed both times in the same spot that it has been failing at. I have also tried different images and get the same results when the image size goes past the point where it fails. Thank you for trying.
Danilo Dy Mon, 02/26/2007 - 06:56
For 3640 after you use the "delete" command, execute "erase" command. You may need to point to "slot0:" or "slot1:" not "flash:", i.e.
3640# delete slot0:c3640-ik9o3s-mz.124-7.bin
or
3640# delete slot1:c3640-ik9o3s-mz.124-7.bin
then..
3640# erase slot0:
or
3640# erase slot1:
If it still doesn't work, can you post the output of the following?
3640# show flash:
3640# show slot0:
3640# show slot1:
We need to see if there is partition.
MikeC5000 Mon, 02/26/2007 - 16:57
It failed again. Here we go:
3640_1#sh flash
1 19578456 c3640-ik9o3s-mz.123-19.bin
[19578520 bytes used, 13451620 available, 33030140 total]
**Here is what is in flash before I start**
3640_1#sh slot0:
%Device 'slot0:' is in REMOVED state
%Error show slot0: (No device available)
3640_1#sh slot1:
%Device 'slot1:' is in REMOVED state
%Error show slot1: (No device available)
**No devices in slot 0 or slot 1**
3640_1#delete flash:c3640-ik9o3s-mz.123-19.bin
Delete filename [c3640-ik9o3s-mz.123-19.bin]?
Delete flash:c3640-ik9o3s-mz.123-19.bin? [confirm]
3640_1#erase flash:
Erasing the flash filesystem will remove all files! Continue? [confirm]
Erasing device... eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee ...erased
Erase of flash: complete
3640_1#delete slot0:
Delete slot0:c3640-ik9o3s-mz.123-19.bin? [confirm]
%Error deleting slot0:c3640-ik9o3s-mz.123-19.bin (No device available)
3640_1#delete slot1:
Delete slot1:c3640-ik9o3s-mz.123-19.bin? [confirm]
%Error deleting slot1:c3640-ik9o3s-mz.123-19.bin (No device available)
**Again, no devices installed**
3640_1#3640_1#copy tftp flash
Address or name of remote host [192.168.1.10]?
Source filename [c3640-ik9os3-mz.124-7.bin]? c3640-ik9o3s-mz.124-7.bin
Destination filename [c3640-ik9o3s-mz.124-7.bin]?
Accessing tftp://192.168.1.10/c3640-ik9o3s-mz.124-7.bin...
Erase flash: before copying? [confirm]
Loading c3640-ik9o3s-mz.124-7.bin from 192.168.1.10 (via Ethernet0/0): !!!!!!!!!
**omitted about a page of !**
3640_1#sh flash
3640_1#sh slot0:
3640_1#sh slot1:
3640_1#
Not sure why you wanted the slot0 and slot1 info, but you have it. Thank you for the try.
MikeC5000 Tue, 02/27/2007 - 02:16
I have tried the tftp server you provided the link for. The download manages to crap-out at the same exact spot every time no matter what tftp server I use or how I try to erase/delete/squeeze the flash. Thank you for trying.
Danilo Dy Tue, 02/27/2007 - 02:35
His problem is he cannot totally erase or squeeze the deleted IOS, therefore there is no room for him to install the same or new IOS.
Mike,
If your router have a back-to-back maintenance with Cisco, you should contact them or your Vendor. Maybe send it for RMA, it could be a hardware problem.
smothuku Tue, 02/27/2007 - 03:31
Hi Mike ,
Have you tried loading the IOS using "copy xmodem: flash:flash name" command.
If you are not able to load the IOS using above command then boot the router in rommon mode and use the xmodem procedure to load the new IOS.
Hope this helps you..
Satish
jamesd058 Thu, 04/12/2007 - 08:54
Were all copies from the same source file? I recently tried to restore an IOS to a 2600 by copying the same IOS to over and over. Then I made a new copy from another 2600 and tried it. Worked first time! Even though it wasn't apparent, it seems my original file was corrupt.
deilert Mon, 03/05/2007 - 04:48
Use FTP , there is a limitation on the tftp file size (32 meg I beleive). Using FTP should allow you to tranfer the file
