Enabling Video on CME
twissam
i went to telephony-service and enabled video: service phone videoCapability 1
The video icon did not show up on the phones until a reboot of the CME.
I beleive there should be a ways simpler and smarter!!! isn't it?
Good day
5 Replies 5
Rob Huffman
Hi Wissam,
Here is the recommended method :)
After video is enabled for the Cisco Unified CME system, you must reset all ephones to register the Cisco Unified CME video capability. Use the following procedure to reset all ephones.
SUMMARY STEPS
1. enable
2. configure terminal
3. telephony-service
4. reset all
5. end
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00806a8017.html#wp1054194
Hope this helps!
Rob
I tried this it will only reset all the IP phones but the video icon will not show.
Good day
Hi Wissam,
That's odd :( How long did you wait after using this method? It would take a while as each ephone is reset sequentially with at least 15 seconds between each reset.
Rob
aha,
I agree with you, there is sequential and the 15 sec interval as you are saying.
i made sure (I saw them) rebooting all the ip phones, i have only 10 (150 sec, not much).
I beleive is when configuring the video service we need to register it like any service, either sh/no sh or reload.
I donno where to look.
thanks for your help, i donno may be i am missing something
Good day
Hey I had the same issue, and i did not have this in, make sure you do.
voice service voip
h323
call start slow
Joel
