!!! Warning: This switch is not usable !!!
Feb 24th, 2007
I have a 3550 Catalyst switch once I power it up, It displays this error message "!!! Warning: This switch is not usable !!!". When I did show run, both the Gigabitethernet/fastethernet ports did not display. If I plug my laptop to the switch my LAN connection shows connected but no light displays on the switch. I assumed the switch has hardware error, or can somebody figure out what the problem is. I have change the IOS several time but still the same problem.
Danilo Dy Sat, 02/24/2007 - 08:10
After that error there will be another line that will tell the cause of the error. Are you still able to collect the output for show tech-support?
royalblues Sat, 02/24/2007 - 11:23
Do you get any other error messages while bootup?
are there any post failures ?
Narayan
