PIX and a 2811
Feb 24th, 2007
I have PIX 515 that I am trying to get to point out to the internet through a 2811.
I can get to the internet through the 2811 if I connect directly to the router, however through the PIX I'm running into some problems.
Router Details:
Internal IP:
192.168.254.2 255.255.255.0
X.X.3.252 255.255.255.240 secondary
External IP:
X.X.1.30 255.255.255.252
Firewall:
Internal IP:
192.168.254.3 255.255.255.0
External IP:
X.X.3.238 255.255.255.240
Now, I can ping the internal interface of the router from the external interface of the PIX, but I cannot get to the external interface of the router from anywhere in the PIX.
I'm pretty sure it has to be a routing issue on the PIX... but I could be very, very wrong. Any help would be greatly appreciated!
Jon Marshall Sat, 02/24/2007 - 14:27
Could be a number of things. When you say "from anywhere in the pix" do you mean from DMZ's / internal networks ?.
If so things to check
1) Routing as you mentioned. Generally speaking you would want a default route on the pix pointing to the 2811.
2) Nat on the pix. Are you doing it or not.
3) access-lists on the pix. If you are pinging from inside the pix to the router you will need an access-list on the outside interface of your pix allowing the ping back in as icmp is not stateful.
Could you explain where you are trying to ping from and send a sanitised copy of the pix config.
Jon
