MPLS basic IOS
Feb 24th, 2007
i do have multiple 2620 adn 2651XM routers and i want to test some MPLS function including the MPLS with BGP and VPN so what is the basic IOS available for the give router?
regards
Devang
ahmednaas Sat, 02/24/2007 - 21:43
MPLS+BGP available only in Enterprise feature sets.
MPLS is available in IOS 12.2(12) and later. I think you'll find limited MPLS support on the 2620's. Use the feature navigator to get more info:
http://www.cisco.com/go/fn
guruprasadr Mon, 02/26/2007 - 02:37
Hello Narayan,
Can you please send me those Config Examples with some Setup Digs to me for Learning Purpose.
Requested the same via Gmail ID also.
Thanks in Advance.
Guru Prasad R
