Adding another Cluster into existing CSS LB
Feb 24th, 2007
Im in the process of adding a new cluster into the existing LB. I understand the concept of configuring a new LB but adding a new network to it is a question.
I have preconfigured the LB with a new service called SPWeb 1-4 and an assign this to the content owner Central_Platform using VLAN 144 and 145.
I have one physical connection to the PIX and all port on the PIX is taken. Do I have to setup another physical connection for the new server SPWeb to the PIX?
Both owners Servcorp and Central_Platform are using separate public IP Subnets.
Also, please advise if I miss anything and if you have any suggestions.
Thansks
!************************* INTERFACE *************************
interface 1/1
bridge vlan 200
interface 2/1
phy 100Mbits-FD
description "To PIX"
bridge vlan 300
interface 2/2
phy 100Mbits-FD
description "To LB switches"
bridge vlan 301
interface 2/3
phy 100Mbits-FD
bridge vlan 303
description "Management"
interface 2/4
phy 100Mbits-FD
bridge vlan 144
description "SPWeb1/2"
interface 2/5
phy 100Mbits-FD
bridge vlan 145
description "SPWeb3/4"
!************************** CIRCUIT **************************
circuit VLAN1
ip address 192.168.10.1 255.255.255.0
circuit VLAN300
ip address (Network 1) 255.255.255.0
circuit VLAN301
circuit VLAN303
circuit VLAN144
ip address (Network 2) 255.255.255.0
circuit VLAN145
!************************** SERVICE **************************
service TS1
ip address 172.16.250.1
active
service TS2
ip address 172.16.250.2
active
service Spweb1
ip address 172.16.144.51
keepalive type HTTP
active
service Spweb2
ip address 172.16.144.52
keepalive type HTTP
active
service Spweb3
ip address 172.16.145.53
keepalive type HTTP
active
service Spweb4
ip address 172.16.145.54
keepalive type HTTP
active
!*************************** OWNER ***************************
owner Servcorp
content hottdesk.au
add service TS1
add service TS2
protocol tcp
port 3389
vip address (Network 1)
active
content hottdesk_FTP
add service TS1
add service TS2
port 20
protocol tcp
active
content hottdesk_FTP2
add service TS1
protocol tcp
port 21
application ftp-control
add service TS2
active
content WebServers_1
add service Spweb1
add service Spweb2
protocol tcp
port 90
vip address (Network 2)
active
content WebServers_2
add service Spweb3
add service Spweb4
protocol tcp
port 81
active
content WebServers_3
add service Spweb3
add service Spweb4
protocol tcp
port 83
active
!*************************** GROUP ***************************
group TS-WebAccess
add service TS2
add service TS1
active
andreas.larsen@... Mon, 02/26/2007 - 00:19
It would help if you could attach a picture of the network. I really can't understand why you have 2 VLANs on the same network ? Or am I missing the ide ?
Generally I would just do VLAN tag towards the PIX and have several networks that way. If speed isn't a issue I see no problems with that.
