Taking IPTT on Thursday---HELP!
Feb 24th, 2007
All, I'm taking the IP telephony troubleshooting exam on Thursday and I'm getting very cold feet. Does anyone have any suggestions on what I should focus on? ANY suggestions will be most appreciated. Thanks.
Just relax :-)
You can only fail and after you fail just do it again :-)
Be sure you know the topics ... if there are blankspots you need to study that first before you go ... but if you know every topic/section and can also explain it to others youre fine ...
If you are not sure about some sections ... ask it here @ the netpro's
If you find this post usefull
please don't forget to rate this
Iwan Hoogendoorn
