02-24-2007 11:01 PM - edited 03-13-2019 03:57 PM
Hi Guru's
I would be greatful if anyone could provide with a URL that illustrate how to add the Logo to Cisco IP 7940 and 7912. With CCM 4.2
I would be greatful if the guide contains with image and steps it would be more convient for me.
Cheers !!!
02-25-2007 12:08 PM
(Also posted in IP Telepony And Unified Communications Application)
7940 does not support change of background image. For 7912, you can refer the following link http://www.cisco.com/univercd/cc/td/doc/product/voice/c_ipphon/english/ipp7905g/admin/ccm42/lowplog.htm
You will need to download SDK from http://www.cisco.com/cgi-bin/dev_support/access_level/product_support to be able to change the image format.
Sorry, it would be though to create a doc with images for this one.
Log in to Community
