Where to put ACL - BRI or Dialer Interface
Feb 25th, 2007
hi,
I have a Dialer interface that is bound to a physical BRI interface. Where should i put my ACL, on the BRI or Dialer interface ? Is there any different ?
Overall Rating: 4 (1 ratings)
mrmozaffari Sun, 02/25/2007 - 02:45
Access-list for what ?
To filter the network traffics or to define interest traffics ?
mrmozaffari Sun, 02/25/2007 - 03:09
Ok.
I got it.
You can assign your access-list to Both Dialer interface and physical interface (Bri).
only the difference is when you assign the access-list to dialler interface it will affects on any Bri interface which they are member of dialer interface ,but if you do this separatly on each bri then you can define more than one kind of access-list i mean like this you can define two access-list 100 and 150 and assign each of them to each bri's.
Best Regards B Mozaffari.
Please Rate if Helpful.
