Cannot access 2811 router from outside
Feb 25th, 2007
I am trying to configure a new router for a new internet connection. I was given the following information from the ISP:
Connected point to point ip:
X.X.1.28/30
Default gateway:
X.X.1.29/30
Routed network IP:
X.X.3.224/28
Now, using the above info I was able to configure the router so that I can access the internet, however nothing from teh outside can see the router. I cannot ping the X.X.1.30 address, I cannot access any of the X.X.3.224/28 addresses.... nothing.
Here is a scrubbed config:
!This is the running config of the router: 192.168.254.2
!version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
no aaa new-model
clock timezone PCTime -8
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
no ip source-route
ip tcp synwait-time 10
ip cef
no ip bootp server
ip name-server X.X.0.22
ip name-server X.X.1.2
ip ssh time-out 60
ip ssh authentication-retries 2
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$$ES_LAN$$FW_INSIDE$
ip address 192.168.254.2 255.255.255.0 secondary
ip address X.X.3.241 255.255.255.240
no ip redirects
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
description $FW_OUTSIDE$$ES_WAN$
ip address X.X.1.30 255.255.255.252
no ip redirects
no ip proxy-arp
ip nat outside
ip route-cache flow
duplex auto
speed auto
no mop enabled
ip route 0.0.0.0 0.0.0.0 X.X.1.29
ip route X.X.3.240 255.255.255.240 X.X.3.254
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet0/1 overload
logging trap debugging
access-list 1 permit any
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
any help would be greatly appreciated!!!
Richard Burts Sun, 02/25/2007 - 17:09
Jim
I have looked at the config that you posted and I see a couple of things that might be issues. I am not clear why you have assigned your provider address space on the inside interface with additional secondary address space:
If the issue is that you have more than 14 devices on the inside interface then I would expect that you would use the provider assigned addresses as a NAT pool and translate the private/inside addresses into the provider assigned addresses.
I also believe that it is an issue that the access list for address translation does a permit any:
This means that that devicdes on the inside interface that are configured in the provider assigned address space of:
X.X.3.240
will be translated into the address space on the outside interface:
I am also having difficulty in understanding the logic of this static route:
why in the world are you attempting to route the provider assigned address space to an address withing that subnet (when that subnet is being translated to something else on the outbound interface)?
Perhaps you can clarify these points?
Rick
Danilo Dy Sun, 02/25/2007 - 18:17
You don't have the following;
ip subnet-zero
ip classless
Why do you have this in your FastEthern0/0
Doesn't sound logical from what your ISP is providing you.
Let us know about your NAT plan, because I think you can't turn on ip cef if you are going to use NAT overload.
