Voice phone dialed improperly after IOS was recovered
Feb 25th, 2007
Hello,guys:
The IOS of Cisco2811 Router couldn't start up normally due to the flash card was damaged.the IOS is going well after I replaced with a new flash card with ios version:c2800nm-ipvoicek9-mz.124-4.T1.bin in it.
after that,voice phone connected to PBX connected to Router 2811 cann't dial normally.
and the voice phone could dial normally
before the flash card was damaged.
config please refer to attachment
MinQuant.Kuo Sun, 02/25/2007 - 19:15
HangLung_CE-SY#sh voice call summary
PORT CODEC VAD VTSP STATE VPM STATE
0/1/0 - - - EM_ONHOOK
0/1/1 - - - EM_ONHOOK
0/2/0 - - - EM_ONHOOK
0/2/1 - - - EM_ONHOOK
HangLung_CE-SY#sh voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/1/0 -- e&m-wnk up dorm idle idle y
0/1/1 -- e&m-wnk up dorm idle idle y
0/2/0 -- e&m-wnk up dorm idle idle y
0/2/1 -- e&m-wnk up dorm idle idle y
why cann't I dial normally using anolog phone through IP network
any help will be great appreciated
MinQuant.Kuo Sun, 02/25/2007 - 19:18
this is sh debug whem dial-up through thone
*Feb 25 14:14:18.807: //-1/50E203468020/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0
*Feb 25 14:14:18.807: //-1/50E203468020/CCAPI/cc_api_call_setup_ind_common:
Interface=0x45E34524, Call Info(
Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subsriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Incoming Dial-peer=10, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
*Feb 25 14:14:18.807: //-1/50E203468020/CCAPI/ccCheckClipClir:
In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*Feb 25 14:14:18.807: //11/50E203468020/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
*Feb 25 14:14:18.807: //11/50E203468020/CCAPI/cc_process_call_setup_ind:
Event=0x45DF6E88
*Feb 25 14:14:18.807: //11/50E203468020/CCAPI/ccCallSetContext:
Context=0x46360B9C
*Feb 25 14:14:18.811: //11/50E203468020/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 11 with tag 10 to app "_ManagedAppProcess_Default"
*Feb 25 14:14:18.811: //11/50E203468020/CCAPI/ccCallSetupAck:
Call Id=11
*Feb 25 14:14:18.811: //11/50E203468020/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
*Feb 25 14:14:18.811: //11/50E203468020/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=TRUE, Tone=Dial Tone,
Tone Direction=Network, Params=0x0, Call Id=11
*Feb 25 14:14:18.811: //11/50E203468020/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
*Feb 25 14:14:18.811: //11/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0xB, digit_event=0x1, enable=TRUE, consume=FALSE)
*Feb 25 14:14:18.811: //11/50E203468020/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=11
*Feb 25 14:14:18.811: //11/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x45E34524, callID=0xB, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*Feb 25 14:14:18.811: //11/50E203468020/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x45E34524, Call Id=11
Call Entry(Initial Digit Timeout=5000(ms), Inter Digit Timeout=5000(ms))
*Feb 25 14:14:20.919: //11/50E203468020/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x45E34524, Call Id=11
Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
*Feb 25 14:14:20.919: //11/50E203468020/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*Feb 25 14:14:20.919: //11/50E203468020/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
*Feb 25
MinQuant.Kuo Sun, 02/25/2007 - 19:35
HangLung_CE-SY>sh voice call
0/1/0 - - - vpm level 1 state = EM_ONHOOK
vpm level 0 state = S_UP
calling number , calling name unavailable, calling time 02/26 03:15
0/1/1 - - - vpm level 1 state = EM_ONHOOK
calling number , calling name unavailable, calling time 02/25 16:08
0/2/0 - - - vpm level 1 state = EM_ONHOOK
0/2/1 - - - vpm level 1 state = EM_ONHOOK
MinQuant.Kuo Mon, 02/26/2007 - 04:53
I have resovled the question through adding signal immediate under voice-port 0/x/x
