Bad magic number when upgrading to pdm-304
I am trying to upgrde pdm from 3(1) to 3(4), when I use tftp and try toinstall pdm-304.bin it appears tostart up and load but always ends with the following message:
Received 3152452 bytes
Bad magic number (0x6f6c636e)
I have tried re-downloading it (seval times) trying both http and passive mode ftp. In windows explorer the file size shows as 3079 so it appears that there is a difference in the numer transmitted. I have tried three different tftp servers and the results have been the same. I did already upgrade the os from 6.3(1) to 6.3(5) using the same procedure.
Anyone have any ideas?
ROBERTO TACCON Sun, 02/25/2007 - 11:36
When you have downloaded the file from cisco have you verified the MD5 ?
Release 3.0.4
Description Cisco PIX Device Manager for PIX 6.3
Size 3152452
Router Checksum 0xba14
MD5 c870b7626bef739f219f4f9a1fa47b53
Date Published: 12-AUG-2005
rajbhatt Sun, 02/25/2007 - 22:31
I have faced the same issue.
Are you trying this for the secondary pix ?
Are you doing this from the moniter mode or config mode ?I tried to do it from the moniter mode as my tftp server would not ping . Mine was a corrupted flash .
Raj
johnrmcse Fri, 04/01/2011 - 23:15
This is what worked for me.........
Cisco PIX Firewall Software Upgrade Procedure
1. Download the latest files for the PIX: Operating System Image and PIX Device Manager (PDM) Image.
2. Prepare a TFTP server, and confirm that the PIX can access it.
3. Log into the PIX Command Line Interface (CLI).
4. Enter enable mode.
PIX# configure terminal
5. Copy the updated operating system image from the TFTP server to the PIX.
PIX(config)# copy tftp flash
Address or name of remote host [0.0.0.0]? 172.17.10.1
Source file name [cdisk]? pix635.bin
copying tftp://172.17.10.1/pix635.bin to flash:image
[yes|no|again]? yes
Received 2101248 bytes
Erasing current image
Writing 1978424 bytes of image
Image installed
6. Copy the latest PDM image from the TFTP server to the PIX.
PIX(config)# copy tftp flash:pdm
Source file name [cdisk]? pdm-304.bin
copying tftp://172.17.10.1/pdm-304.bin to flash:pdm
[yes|no|again]? yes
Erasing current PDM file
Writing new PDM file
7. Reboot the PIX.
PIX(config)# reload
8. Type show version to verify that the upgrade succeeded.
PIX# show version
Cisco Secure PIX Firewall System 6.3(5)
PIX Device Manager Version 3.0(4)
