02-25-2007 04:35 PM - edited 03-05-2019 02:33 PM
Is there any advantage or disadvantage to setting keepalive to ports on a switch?
eg.. setting keepalive for 10sec on port16 on a 2924 switch?
Solved! Go to Solution.
02-25-2007 09:16 PM
By default is enabled to 10 sec. No need to change the value. It doesn't degrade the performance. Ofcourse if you reduce the timer there is more load on it.
Cheers
Hoogen
02-25-2007 05:56 PM
When you set no keepalives your port stays UP. When you do set keepalives usually 10sec by default, the port would keep checking if your PC is online every 10 sec.
Hoogen
Do rate if this soln had helped :)
02-25-2007 09:00 PM
ahh, thanx much appreciated.
So by issuing the keepalive (time), would that degrade switch performance or not?
02-25-2007 09:16 PM
Cheers
Hoogen
