Redirect multiple ports to (1) IP on a PIX 501 ver. 6.3(5)
Feb 25th, 2007
I am trying to forward a range of ports ex. 1024-2048 to (1) internal address using statics? Is there an easy way?
Overall Rating: 3 (1 ratings)
vitripat Mon, 02/26/2007 - 09:34
Unfortunately, there is no easy of doing this. We would need to put indpendent static commands for each port. :-(
Hope this answers your question.
Vibhor.
acomiskey Mon, 02/26/2007 - 09:52
I assume you're forwarding other ports on that same address. But, if you're not using this address for anything else, you could just forward all ports and write an acl to only allow 1024-2048.
briannctrl Mon, 02/26/2007 - 12:07
Thank you. Unfortunately is does answer my question. Is there a limit to the number of statics that can be entered into a PIX 501.
vitripat Mon, 02/26/2007 - 12:12
As such, there is no limit defined. Logically, a static statement would take around 120 bytes of memory. So you could use as many as they fit into the memory on your PIX.
Vibhor.
