limit the access by routing protocls
Feb 25th, 2007
we have too many branches that connected to headquarter with ospf protocols , we have department that is connected to HQ by EIGRP , so we want each of the branches have access to HQ & these department .so , in the routing table of each branch we have EIGRP & ospf routing protocols .But we don't want that branches have access to each other at all. as regards , we have IPsec between each branch to HQ , & we introduce interesting traffic,could u pls tell me , what can I do (solution) to limit these access ?,
route filtering , could be a suitable solution?
thanx
cpembleton Sun, 03/11/2007 - 21:30
You can use route-maps to control which routes the routing protocols are sending.
Here is an ospf example: EIGRP would be similar.
access-list 10 permit 192.168.10.0 0.0.0.255
route-map ospf-filter deny 10
match address 10
route-map ospf-filter permit 20
router ospf 1
router-id 10.0.0.2
log-adjacency-changes
network 172.16.2.1 0.0.0.255 area 0
network 192.168.10.0 0.0.0.255 area 1
distribute-list route-map ospf-filter out
Hope this helps.
Chad
Please rate if it does.
