CUE editor
Feb 25th, 2007
Hi All,
I am using CUE editor. I want the AA only transfer the call to specific extensions. then I insert "if" statement to the script but it seems I have to insert "if" same number as extensions which make AA too long. Is there any "or" option for Boolean expression in CUE editor? like "if extension==
"106" or extesion=="107 or ...." instead of inserting ten times "if" statement.
thanks
Alex
