limt the access via routing protocols
Feb 25th, 2007
we want to limt the access between branches without ACL, we have EIGRP,OSPF ,STATIC route in our routing table. could I do it with route filtering? is it a good solution?
could you pls tell me the other solution for this subject?
we have some problems with ACL in branches .
with these routing protocols , could we use route filtering?
thanx
Amit Singh Sun, 02/25/2007 - 23:20
You can configure the route filtering on the routing protocols mentioned above.This is a typical configuration used in a hub-spoke topology. Please see the links below for more info on this:
http://www.cisco.com/en/US/tech/tk365/tk207/tsd_technology_support_sub-protocol_home.html
http://www.cisco.com/en/US/tech/tk365/tk480/tsd_technology_support_sub-protocol_home.html
HTH,
-amit singh
