PIX 7.2(2) Remote Access VPN issue
Feb 26th, 2007
I have been trying to connect a VPN Client for remote access to a PIX515E (using version 7.2(2). I can get to the user authentication window, but after I enter the username and password, I get the status "Not Connected". I tried to run "debug crypto isakmp" but only the following screen output is appearing:
PIX(config)#
Jun 27 17:00:08 [IKEv1]: Group = testgroup, Username = testuser, IP
= 173.5.1.4, Removing peer from peer table failed, no match!
Jun 27 17:00:08 [IKEv1]: Group = testgroup, Username = testuser, IP = 173.5.1.4,
Error: Unable to remove PeerTblEntry
Can anybody help me identify the cause of the problem? Your response will be greatly appreciated.
Lorenz
acomiskey Mon, 02/26/2007 - 07:02
You also appear to be missing
access-list outside_cryptomap_dyn_10 extended permit ip any 192.168.1.0 255.255.255.0
crypto dynamic-map pixdyna 10 match address outside_cryptomap_dyn_10
l.tating Tue, 02/27/2007 - 18:33
Thank you guys, for the additional input, however, after I applied them, I still cannot get connected. I still keep on getting the same message. Thank you for your further assistance.
Lorenz
Wizzle Wed, 02/28/2007 - 07:17
Hey l.tating , I had the exact same problem with connecting to a pix. Under the aaa-server line I didn't have the correct key. So I would recommend that you check they key to verify. You can use this command also - debug crypto isakmp 7
l.tating Thu, 03/01/2007 - 00:00
Hello Wizzle,
I am not using aaa for authentication. Im just using local database. I still cannot make it work. My debug crypto isakmp 7 has something in it that showed "cannot obtain an IP address for remote peer". Please see debug messages below:
Jun 30 15:46:22 [IKEv1]: Group = testgroup, Username = testuser, IP = 173.5.1.4,
Cannot obtain an IP address for remote peer
Jun 30 15:46:22 [IKEv1 DEBUG]: Group = testgroup, Username = testuser, IP = 173.
5.1.4, IKE TM V6 FSM error history (struct &0x27a61b8) , : TM_DO
NE, EV_ERROR-->TM_BLD_REPLY, EV_IP_FAIL-->TM_BLD_REPLY, NullEvent-->TM_BLD_REPLY
, EV_GET_IP-->TM_BLD_REPLY, EV_NEED_IP-->TM_WAIT_REQ, EV_PROC_MSG-->TM_WAIT_REQ,
EV_HASH_OK-->TM_WAIT_REQ, NullEvent
5.1.4, IKE AM Responder FSM error history (struct &0x27db608) , :
AM_DONE, EV_ERROR-->AM_TM_INIT_MODECFG_V6H, EV_TM_FAIL-->AM_TM_INIT_MODECFG_V6
H, NullEvent-->AM_TM_INIT_MODECFG, EV_WAIT-->AM_TM_INIT_XAUTH_V6H, EV_CHECK_QM_M
SG-->AM_TM_INIT_XAUTH_V6H, EV_TM_XAUTH_OK-->AM_TM_INIT_XAUTH_V6H, NullEvent-->AM
_TM_INIT_XAUTH_V6H, EV_ACTIVATE_NEW_SA
5.1.4, IKE SA AM:f7413097 terminating: flags 0x0945c001, refcnt 0, tuncnt 0
5.1.4, sending delete/delete with reason message
5.1.4, constructing blank hash payload
5.1.4, constructing IKE delete payload
5.1.4, constructing qm hash payload
Jun 30 15:46:22 [IKEv1]: IP = 173.5.1.4, IKE_DECODE SENDING Message (msgid=8ba4c
5b) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 80
Lorenz
at Mon, 03/19/2007 - 16:34
hi,
please can you send me your current configuration from your pix
regards
alex
