basic configuration of CSS11500
Feb 26th, 2007
hi I am new to CSS. i need to know some very basic things. how to connect the device to the network and how the basice interfaces configuration can be done? like adding an IP address to the managemnt interface, accessing the GUI etc. Any help will be highly appreciated
Gilles Dufour Mon, 02/26/2007 - 09:00
To set an ip on the managment interface:
conf t
boot
ip address x.x.x.x
subnet mask x.x.x.x
The port on your switch should be set to half-duplex 10Mb.
To access this ip you need to be in the same subnet.
If you need to access it from a remote location, you can add a static route [no default route].
exit the boot mode and type
ip management route ....
Gilles.
