Is it possible to install SDM on old CISCO 2610?
Answered Question
Feb 26th, 2007
Hello all,
I have CISCO 2610 (not "XM" series) and NM4-E module for my labs. Is it possible to install SDM on it?
Extra info:
Bridgecom2610#sh ver
IOS (tm) C2600 Software (C2600-IPBASE-M), Version 12.3(9c), RELEASE SOFTWARE (fc 2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Tue 30-Nov-04 23:51 by kellythw
Image text-base: 0x80008098, data-base: 0x80F1D424
ROM: System Bootstrap, Version 11.3(2)XA2, PLATFORM SPECIFIC RELEASE SOFTWARE (f
c1)
Bridgecom2610 uptime is 1 hour, 59 minutes
System image file is "flash:c2600-Ipbase-mz.123-9C.bin"
cisco 2610 (MPC860) processor (revision 0x200) with 39936K/9216K bytes of memory
Processor board ID JAB0221001C (598769124)
M860 processor: part number 0, mask 32
Bridging software.
X.25 software, Version 3.0.0.
5 Ethernet/IEEE 802.3 interface(s)
4 Serial(sync/async) network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Thank you!
Correct Answer by Amit Singh about 9 years 7 months ago
Hello, its not supported on 2600 routers. Its only supported on 2600XM series.
http://www.cisco.com/en/US/products/sw/secursw/ps5318/prod_installation_guide09186a00803e4727.html#wp37069
HTH,Please rate if it does.
-amit singh
Correct Answer by hoogen_82 about 9 years 7 months ago
http://www.cisco.com/en/US/products/hw/routers/ps259/products_data_sheet0900aecd800fa5be.html
SDM support seem to be only 2610XM routers.
I also checked up the software advisor, SDM support only on 2610XM not on 2610.
Hoogen
Do rate if i have helped :)
Overall Rating: 5 (3 ratings)
