Unity Diagnostic Tool
Feb 26th, 2007
I have installed a Unity 4.0(5) server for a customer, I tried opening the Unity Diagnostic tool but received an error message from MMC informing me that the Snap-In failed to initialize. I should have seen all the common diagnostic tools and the logos but I just get a blank screen.
If I open MMC on its own and then browse to the UnityDiagnostics.msc file I also recieve the same error, however if I open other *.msc files they appear to open ok.
Has anyone else come across this issue before? Everything else with the Unity server is running ok.
Glen
Overall Rating: 5 (1 ratings)
gogasca Mon, 02/26/2007 - 06:33
Hi Glen,
Manually register the file UnityDiagnostics.dll, as follows:
1. Open a command prompt window and go to the directory where Cisco Unity is installed.
2. Go to the Utilities\UnityDiagnosticTool sub-directory.
3. Enter the following:
regsvr32 UnityDiagnostics.dll
gcobby Mon, 02/26/2007 - 07:54
Thanks for your help, this resolved my issue.
Glen
