A perfect hardwares
Feb 26th, 2007
how to build a network with 12th floor ?
what is the right type hardware or equipment such as switch, cable, etc and also integrated with a security camera..?
please does anyone can help me..?
Overall Rating: 5 (2 ratings)
Danilo Dy Mon, 02/26/2007 - 03:59
What is the estimated number of user and growth per floor?
What is the application use that needs access to the network like printer, file sharing, mail, etc.. to determine the maximum throughput in the core?
algifary_ra Tue, 02/27/2007 - 18:59
depend on the situation..but right know each floor had 25 client.. and the application using oracle for the database..windows 2000 advanced server SP 4, Fedora Core 5, and Novell Server 6.5
regards
ahmednaas Mon, 02/26/2007 - 08:56
Do you mean a building with 12 floors?
Where will your core equipment be located?
How large is each floor?
Do you need redundancy/ High availability?
Do you want to integrate VoIP?
Some basics: (assuming you want Cisco gear)
You should use cat6 cable from your access switches to the desk.
You should use fiber optic cable to connect the floors to the core.
Access/distribution switches: 3560's/4500's ?
Core Switches: 6500 series.
Routers: ISR 2800/3800 series
Use IP cameras for security (separate VLAN) with digital recorders.
algifary_ra Tue, 02/27/2007 - 19:09
right a building with 12 floors
core equipment located at 1st floor
large each floor 110 m
i need high availability and integrate wit h VoIP
regards
cratejockey Sat, 03/03/2007 - 08:52
Wow this is a tall request for a NetPro question... I'll try to throw some valid insite into this but no promises. If your new to networking and or uncomfortable with doing this large of an install I would contact a Cisco Partner/Designer. I'm sure your local Cisco Rep can point you in the right direction. I have some names I could send you as well.
On to the question though.
Your requirement for High Avail and VOIP will drive a few things.
1. CORE: Best case would be a pair of Chassis. Deciding what model is another issue. If you plan on just going switching and routing off of it then just use the 4500 series. In order to get you up 12 floors your going to need to use Fiber links so SFF fiber cards and GBICS will be your best bet here and will leave room for expantion. Using redundant 4500's should allow you to use 4506's. If you cant justify dual 4500's the use a single 4507R with Dual Supervisor modules. In either case your redundant links to your edge switches should not come from the same line card. In the case of redundant 4506's thats simple one link to chassis 1 and another to chassis 2. In the case of a 4507R you would need multiple line cards and you would connect link 1 to line card 1 then link 2 to line card 2.
Again redundancy planning and implementation should not be take lightly your companies revenues might depend on this being done right.
2.EDGE: You have a bunch of options here. Based on your end user numbers you could probably go with 2960 POE switches. Cisco has done something interesting with their switch line in this latest offering. That something is that the high end 2960's, the 3560's 3760's and 6509's with Sup32 all use a 32 Gbps backplane. So as far as backplane (port to port communication) goes it is a pretty even playing field. Its when you start looking at features of the different model that you need to be careful in your choices. With VOIP in your plans you need to put lots of thought into what phones you plan on using and what voltages they pull. Based on your requirements for HighAvailability you will want to make sure that you have 4 SFF interfaces on your edge switches. This will allow two ports back to your CORE and at least one more to trunk to another switch in the closet. The trunk to another switch will create a failover path if your fiberlinks to your core are cut or if your CORE goes off line will provide at least switched access for clients on the same LAN/VLAN.
I'm going to cut it off there because this could go on and on. When we do this for clients we usually have multiple planning sessions and both engineering drawings of the facility and Logical drawings of the network to plane the scope and scale of the project.
I will monitor this conversation and will gladly answer any more questions you might have or pass along information you might need.
Good Luck,
www.staticnat.com
Danilo Dy Sat, 03/03/2007 - 23:24
Ok, before we throw some equipment recommendation to you, what is the estimated budget for this project for the network equipment only? Please do not include budget in the cabling, racks, and other miscellaneuos expenses
Take note that for every project, budgetting is important. The budget includes one-time and recurring.
