Where are CDR exported files?
Answered Question
Feb 26th, 2007
I exported CDR and CMR files with CAR but I don't know where directory CAR export it.
I tried to find *.csv files in my hard disk CCM server and I have no result.
Can anybody help me?.
Correct Answer by mchandak about 9 years 7 months ago
the file would be a txt file and check c:\CiscoWebs\art\reports\OnDemand\temp folder. This should have a .txt file. The CDR file would have CDR at the end of the file name and CMR will have CMR at the end.
I hope this helps.
Overall Rating: 2.5 (4 ratings)
carlostrapiello Mon, 02/26/2007 - 07:33
Yes. I go to CAR| CDR Menu | Export CDR|CMR |
but I have no link.
I have the screen that I add to this post and after I press the button in the image that I attached and CDR export my CDR's and CMR's but I don't know where and I can't to select where I want to save exported files..
I use CCM 4.1
Correct Answer
mchandak Mon, 02/26/2007 - 09:04
I hope this helps.
