NAR to allow Reverse Telnet only
Answered Question
Feb 26th, 2007
Hi .. i'm trying to restrict access to a modem attached to the aux port (2065)of a 2600.. i've created an IP based permit NAR with the AAA Client, port:2065, * .. which if i read correctly should give rev telnet access to just #.#.#.# 2065.
when i apply the nar the failed log shows 'User Access Filtered'. if i take the nar off it works fine so i'm pretty sure its a group problem rather than device config.
does the port apply to the src rather than dst port ?
Correct Answer by darpotter about 9 years 7 months ago
Theres good info here (http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_white_paper09186a00801a8fd0.shtml#wp39282) about where the data port field comes from.
Basically from the port field in the TACACS+ header is matched against the NAR port entry.
I did a quick test using tactest with an IP based NAR allowing access to a test device on port tty1 from 1.1.1.1 and it worked:
TACACS> authen login ascii login tty1 1.1.1.1
User Access Verification
Username: daz
Password: 123456
Authentication succeeded :
TACACS> authen login ascii login tty2 1.1.1.1
Username: daz
Password: 123456
Authentication failed
Look in your Failed Attempts report. Whatever value is in the "NAS-Port" column is one used by the NAR. I guess its possible for reverse telnet IOS might send the destination port.
Darran
Overall Rating: 5 (1 ratings)
Correct Answer
darpotter Tue, 02/27/2007 - 03:09
Username: daz
Password: 123456
Username: daz
Password: 123456
Darran
pregan Tue, 02/27/2007 - 03:43
your a star .. i had assumed as the NAR was IP based that the port reflected the IP port not the router assigned tty ..
putting tty65 in the NAR has resolved my problem.
