Which monitoring product to use?
Feb 26th, 2007
Dear Netpro,
We have a customer who currently wants to be able to monitor their switches. We already monitor them through solarwinds as their IT supplier. They already have MRTG running for monitoring their 2 x 100 Mbps LES circuits on the 2621 XMs
We are suggesting solarwinds as one of the options, but the cost may an issue, they have the following;
2 x 3550-48-EMI
1 x 3550-12G-EMI
4 x 3500XL (48 ports)
2 x 2621 XM routers
so 316 ports to monitor !
Requirements
*Be able to set users thresholds on port utilisation and notify via email if breached.
*has a dashboard layout if problems need to be investigated.
*is VERY simple to use!
*has syslog function
*can be used by multiple users, up to 4 it support staff.
*has some form of graphing utilising to look at stats
*has some ability to measure QoS as being used by Avaya phone system.
Thanks in advance for your assistance.
I always rate helpful posts.
Best Regards, Adrian.
Overall Rating: 3.5 (2 ratings)
aoshea Mon, 03/05/2007 - 01:49
This only seems to support high-end switches such as the 6500's. Is there any support for the lower end switches such as the 3550's?
thanks again.
regards, Adrian.
