ccme + sip provider
Feb 26th, 2007
I tried to connect my ccme 4.0 with a sip provider. I managed to configure it for outgoing calls, but I'm unable to get incoming calls...
Can sombody show me how it works ?
Overall Rating: 5 (1 ratings)
gogasca Mon, 02/26/2007 - 07:11
Configure an incoming dial peer which match codecs used by your provider.
For example:
dial-peer voice 4001 voip
voice-class codec 1
incoming called-number 5...
dtmf-relay rtp-nte
Where 5... are your extensions and in class codec you have:
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
kern.jerome Mon, 02/26/2007 - 07:28
Thanks, but my provider send me a 10 digits number and I want to transalte it in a number like 2..
Paolo Bevilacqua Mon, 02/26/2007 - 07:40
Just configure the 10 digits number as secondary in the corresponding ephone-dn. You can also configure sip-ua and it will register this number (no-reg primary) to the ITSP.
Then, "debug ccsim message" is your friend and will tell you what the ITSP is sending, and why is rejected.
gogasca Mon, 02/26/2007 - 07:46
You can create a translation rule like the following:
Lets say your provider sent you:
919 991 5454
voice translation-rule 100
rule 1 /^919....\(...\)$/ /\1/
voice translation-profile TOEXT
translate called 100
dial-peer voice 2000 voip
translation-profile incoming TOSIP
session protocol sipv2
dtmf-relay rtp-nte
codec g711ulaw
This should do it.
Number converted will be 454
or use:
dialplan-pattern command
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_administration_guide_chapter09186a00801f12a8.html#wp2261346
Paolo Bevilacqua Mon, 02/26/2007 - 08:09
Again, the voice translation-rule, although a very powerful tool, is not necessary in this case.
The secondary number in ephone-dn, is instead what the CME architecture gives you to easily route call coming in as "pots" numbers.
kern.jerome Mon, 02/26/2007 - 08:06
Here you can see part of my configuration. It still don't work...
The dial-peer 3 should the one which is used for incoming calls ...
dial-peer voice 1 voip
translation-profile outgoing OutgoingProfile
destination-pattern T
session target ipv4:213.161.201.200
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 2 voip
destination-pattern 8..
session target ipv4:10.10.0.33
session transport tcp
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 3 voip
incoming called-number 0877192763
dtmf-relay rtp-nte
codec g711alaw
sip-ua
authentication username login password ****
sip-server ipv4:213.161.201.200
notify telephone-event max-duration 500
ephone-dn 1 dual-line
number 200 secondary 0877192763 no-reg primary
Paolo Bevilacqua Mon, 02/26/2007 - 08:14
can you post output of "debug ccsip message" ? You will need of course "term mon" to see it on a telnet connection.
Dial-peer 3, being an incoming only, does not even need "session protocol", but I'm not sure if this is the problem.
kern.jerome Mon, 02/26/2007 - 08:22
I get no messages from a debug command using a console connection.
I will phone the provider to see if he can see something wrong ...
Paolo Bevilacqua Mon, 02/26/2007 - 12:30
You must be able to see debug output, that is key to working with routers. Telnet to the router, and type "terminal monitor" before or after the debug commands.
kern.jerome Tue, 02/27/2007 - 00:30
I can show debug, but only during outgoing calls... nothings appears during an incomming call. That's why I'm trying to find a solution directly with my provider.
I'll let you know
Paolo Bevilacqua Tue, 02/27/2007 - 13:24
Possibly you need to register with ITSP ro receive incoming calls. Create a "voice register dn" with the number that ITSP wants to be registed and a register server in sip-ua.
Paolo Bevilacqua Tue, 02/27/2007 - 16:45
Woops, I see that your local phones are SCCP. Then no "voice register dn" is necessary, just "registrar" under "sip-ua".
kern.jerome Wed, 02/28/2007 - 03:16
Another question..
If I configure my cisco like you said, the ephone-dn registers the phone number with the secondary line.
Is possible to register with a dial-peer or something else to use hunt-groups ?
Paolo Bevilacqua Wed, 02/28/2007 - 06:27
Hi Kern,
You can indeed register pots dial-peers but I don't think that is what you want.
To "register" an hunt group, just create an ephone-dn with number assigned by the ITSP, either primary or secondary, and registering. Then in this ephone-dn, configure Call Forward All to the actual pilot number of the hunt group you want to use.
kern.jerome Wed, 02/28/2007 - 06:58
The problem is that I have to put my sip login instead of the e164 number to make it work (my sip provider told me that):
number 200 secondary login_sip no-reg primary
I don't know how it works if I had multible sda (e164 numbers) with the same login...
Paolo Bevilacqua Wed, 02/28/2007 - 07:13
Well, it should work.
The number in ephone-dn must be a number and not an username, because it's what CME will try to register, and it's not possible to register an username.
In many cases, ITSP assigns the username to be the same as number, but not always.
The thing is that under sip-ua you can configure "credentials username/password/realm", so you can register as many numbers you want using the same set of credentials.
kern.jerome Wed, 02/28/2007 - 07:57
Here you can see the sip-ua section and my ephone-dn configured with the login and the e 164number. I also pasted the sh sip-ue register status associated
Do you think that the problem is coming from my provider?
sip-ua
authentication username "sip_login" password ****
registrar ipv4:registrar_ip_address expires 60
sip-server ipv4:registrar_ip_address
number 200 secondary "sip_login" no-reg primary
label 200
description 200
Router#sh sip-ua register status
Line peer expires(sec) registered
"sip_login" 20008 45 yes
number 200 secondary "e164_number" no-reg primary
label 200
description 200
"e164_number" 20008 110 no
Paolo Bevilacqua Wed, 02/28/2007 - 08:16
What can I say, this ITSP does things differently.
If I understand correctly, he wants you to register the username only, and I suppose that they will present calls to all your numbers to the system where you registered from.
To the CME, that does do not make much a difference, as long the SIP username contains only digits/abcd to be used as number in ephone-dn.
Configure an ephone-dn, single-line, primary number, registering as the username assigned. The only purpose of this will be triggering registration. Or, just do a you did an reause an existing ephone-dn as secondary number.
Configure all the others ephone-dn with the secondary numbers that you got, and no-reg both.
Ephone-hunt also supports secondary number and should work as well.
