no track rtr command anymore
Answered Question
Feb 26th, 2007
I want to make use of ip sla, but the "track 100 rtr 1 ..." command fails
example:
ip sla 1
icmp-echo 10.1.1.1 source-interface FastEthernet0
timeout 10000
threshold 2
frequency 15
ip sla schedule 1 life forever start-time now
ip sla 2....
track 100 rtr 1 reachability
track 200 rtr 2 reachability
it places the dreaded carrot on the rtr keyword.
I am running ip-base 12.4.11 t1 on a 3745.
Do I have to move up to advanced ip or enterprise for this feature.
I want to be able to use tracking ip sla for ip next-hop verify-availability 10.1.1.1 10 track 100
Correct Answer by Ahmede about 9 years 7 months ago
This command is not supported in IP-Base nor Advanced IP, you will have to upgarde to a higher feature set..
Enterprise base will do..
12.4(11)T1 c3745-entbasek9-mz.12.4-11.T1
Overall Rating: 5 (1 ratings)
Correct Answer
Ahmede Mon, 02/26/2007 - 08:13
ericgarnel Mon, 02/26/2007 - 09:10
If the non crypto images will work, I am home free. Otherwise, I will have to get some more flash
