Split NATting internet/VPN
Feb 26th, 2007
There is an IPSecVPN tunnel between 2 routers. On both sides there are subnets in use, and several are the same. :-(
So there is a need for NATting through the tunnel.
Part of the config:
ip nat pool Portugal1 10.35.1.10 10.35.1.254 netmask 255.255.255.0
ip nat pool Portgual2 10.35.2.12 10.35.2.254 netmask 255.255.255.0
ip nat inside source list 2 interface Dialer0 overload
ip nat inside source list 69 pool Portugal1
ip nat inside source list 70 pool Portugal2
ip nat inside source static 172.27.0.2 10.35.2.2
ip nat inside source static 172.27.0.10 10.35.2.10
ip nat inside source static 172.27.0.11 10.35.2.11
ip nat inside source static 10.35.1.1 192.168.0.1
ip nat inside source static 10.35.1.2 192.168.0.2
ip nat inside source static 10.35.1.3 192.168.0.3
ip nat inside source static 10.35.1.4 192.168.0.4
ip nat inside source static 10.35.1.5 192.168.0.5
ip nat inside source static tcp 10.35.3.1 22 213.205.88.132 22 extendable
ip nat inside source static tcp 10.35.3.1 25 213.205.88.132 25 extendable
ip nat inside source static tcp 10.35.3.1 80 213.205.88.132 80 extendable
ip nat inside source static tcp 172.27.0.202 80 213.205.88.132 81 extendable
ip nat inside source static tcp 10.35.3.1 110 213.205.88.132 110 extendable
ip nat inside source static tcp 172.27.0.11 3389 213.205.88.132 3389 extendable
ip nat inside source static tcp 10.35.3.1 10000 213.205.88.132 10000 extendable
no logging trap
access-list 2 permit 172.27.0.0 0.0.0.255
access-list 2 permit 192.168.0.0 0.0.0.255
access-list 2 permit 10.35.3.0 0.0.0.255
access-list 120 permit ip 10.35.3.0 0.0.0.255 192.168.205.0 0.0.0.255
access-list 120 permit ip 10.35.1.0 0.0.0.255 192.168.205.0 0.0.0.255
access-list 120 permit ip 10.35.2.0 0.0.0.255 192.168.205.0 0.0.0.255
There are 2 NATtings that conflict:
- ip nat inside source list 2 interface Dialer0 overload
and
- ip nat inside source static 172.27.0.2 10.35.2.2
The configuration should be so that when the server (172.27.0.2) tries to connect to the internet, the 1st natting is used and when the server is speaking to a host through the tunnel, the 2nd natting is used.
How can this be done?
Thanks!
Jon Marshall Mon, 02/26/2007 - 10:54
You can do this with a route map eg.
access-list 101 permit ip host 172.27.0.2 "remote network" "subnet mask"
access-list 101 deny ip any any
ip nat inside source static 172.27.0.2 10.35.2.2 route-map server_vpn
route-map server-vpn
match ip address 101
I've attached the link to a Cisco doc on using route-maps with static NAT translations.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087bac.html
Jon
