recommended upgrade for 4.0 versions
Feb 26th, 2007
Hello All,
In 3.0 I learned that some versions created various issues. One of the recommended versions was 3.2.150.10.
With a 4.0 WCS and 3.0 controllers. What are the recommendations as to a version that is relatively stable to upgrade the controllers to?
WCS is 4.0.81.0
Thanks!
Erik
Overall Rating: 4 (1 ratings)
MICHAEL SCHROEDER Wed, 02/28/2007 - 12:37
Hi Erik, i tested it with various Versions 2 weeks ago, from 4.0.179 to 3.2, back to 4.0.206, it works very well (i recommend to use 4.0.206). Also you can update the WCS, back it up, de-install it, install 4.0.96 and restore the database, the license should be also restored. Regards, Michael
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
