configuring Vlan on cisco 2900xl switch
Feb 26th, 2007
hello
i m applying vlan on my cisco 2900xl switch
i want 2 make the range (port no 8 to port no 16) a part of my vlan 10.
what is the range command to make this range of ports to be the part of vlan 10.
Overall Rating: 4 (1 ratings)
nacertified Mon, 02/26/2007 - 10:52
hello
thanx for the command.i try it but it doesn't accept it.the ios version of cisco 2900xl switch is "Version 12.0(5.2)XU"
any further suggestions--?
ahmednaas Mon, 02/26/2007 - 10:58
the 2500xl-3500xl software doesn't support the range command.
jegrimm Mon, 02/26/2007 - 23:59
You can try cut/paste the config (sh run) into a notepad window, then modify the settings on a few and cut/paste the changes for the rest of the interfaces.
Once you are done with the config, cut/paste into the configur mode.
Cheers,
Jim
