Documentation to 7985
Feb 26th, 2007
Someone have some documentation for development for 7985 model?
stephan.steiner Wed, 02/28/2007 - 01:34
In terms of services, it should have the same capabilities as a 7970. In terms of CTI, all IP phones are the same anyway (well, perhaps the pre 79xx series were different but I doubt they're widely used anymore).
Take the phone services part under advisement because the development guide, even for ccm 5.1, doesn't mention the phone type, but if you know it does xml, then my statement should be correct (and you can easily verify that by pushing a simple to the phone and see what it does with it).
paulogentile Wed, 02/28/2007 - 03:12
I tested many tags and that tags work witch 7985 in the same way of 7970:
CiscoIPPhoneText
CiscoIPPhoneInput
CiscoIPPhoneImageFile
but others didn't worked.. i heard that some differences in the tag to work proprely in the 7985
