CDP-EV: Bad checksum in header
Feb 26th, 2007
I have a 3560 (ios 12.2(25)) connected to L3 module (ios 12.0(14)) on catalyst 4006.
I can see 3560 as a CDP neighbour on L3 module, but I can NOT see L3 module on 3560 as CDP neighbour
L3 communications are OK.
debug cdp events on 3560 shows:
show cdp traffic on 3560 shows checksum errors:
Chksum error: 13
cdp v2 ads. are disable on 3560
Can you help me. Thanks.
manuel.
pd. I know this is little problem because IP communication is OK, but you know costumers...
didyap Fri, 03/02/2007 - 11:41
If the trunk link between the router and the switch is ISL there could be some issues.It includes ISL header length, which cause bad checksum.Also check to see if they are using same version.
