map-class frame-relay , policy map
Answered Question
Feb 26th, 2007
Does a service-policy output have to be applied to an interface for qos to work?
here is the config but there is nothing applied to the serial interface..
Thanks for your help
policy-map 256/128KVoice
class 256/128KVoice
priority 112
class class-default
fair-queue
map-class frame-relay 256/128KVoice
frame-relay cir 128000
frame-relay bc 1280
frame-relay be 600
frame-relay mincir 128000
no frame-relay adaptive-shaping
frame-relay fair-queue
frame-relay fragment 150
frame-relay ip rtp priority 16384 16380 210
interface Serial0/0
bandwidth 1544
ip address xxx.xxx.xxx.xxx 255.255.255.255
ip route-cache flow
no fair-queue
service-module t1 timeslots 1-24
Correct Answer by Brandon Buffin about 9 years 7 months ago
Yes, the policy must be applied to an interface/sub-interface for QoS to take affect. Take a look at the QoS SRND for specific examples. Look under WAN Aggregator QoS Design -> WAN Edge Link-Specific QoS Design.
QoS SRND
http://www.cisco.com/univercd/cc/td/doc/solution/esm/qossrnd.pdf
Hope this helps. If so, please rate the post.
Brandon
Overall Rating: 5 (2 ratings)
ud0508500 Tue, 02/27/2007 - 04:18
Great....thank you for your time and help
greatly appreciate it..
Quick question about fair-queue.
should this be set on the interface as well, as it sits now there is no fair-queue on the serial interface
Brandon Buffin Tue, 02/27/2007 - 05:28
The fair-queue command is not necessary on the serial interface. The command in the policy map for class class-default will fair-queue all traffic not in the 256/128KVoice class.
Brandon
kumar-brajesh Thu, 07/14/2011 - 03:55
Will QOS will work in this way  where class is put on WAN interface where it should be service  policy.
router#sh run interface Se0/0/0.1
Building  configuration...
Current configuration : 239 bytes
interface  Serial0/0/0.1 point-to-point
bandwidth 2048
ip address XXXX
ip nat outside
frame-relay  interface-dlci 555
  class COS-OUT-S0/0/0.1
end
COS-OUT-S0/0/0.1 is defined as policy map  with class of voice and video.
When checking on WAN int #sh policy-map  interface  Se0/0/0.1 , can see output of service policy input/output with policy map  recpective classes and packets match entries.Is  QOS working with this  configuration?
Appreciate any input on this.
Brajesh.
