RSVP not connected
Feb 26th, 2007
I am setting up the first agent for my RSVP configuration, and when doing a sh sccp i get this. Showing I failed to register with CCM. I am running CM5.1 using IOS c2800nm-spservicesk9-mz.124-11.T1.bin on a 2811 gateway.I have a MTP on CM called "MTPEast2". Any ideas why it fails to register?
Thanks Dan
East-2811-1#sh sccp
SCCP Admin State: UP
Gateway IP Address: 10.1.130.2, Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.1.130.11, Port Number: 2000
Priority: N/A, Version: 5.0.1, Identifier: 1
Call Manager: 10.1.130.10, Port Number: 2000
Priority: N/A, Version: 5.0.1, Identifier: 2
Call Manager: 10.1.140.10, Port Number: 2000
Priority: N/A, Version: 5.0.1, Identifier: 3
Software MTP Oper State: ACTIVE_IN_PROGRESS - Cause Code: CCM_REGISTER_FAILED
Active Call Manager: 10.1.130.11, Port Number: 2000
TCP Link Status: NOT_CONNECTED, Profile Identifier: 20
Reported Max Streams: 200, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: pass-thru, Maximum Packetization Period: N/A
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period
: 30
RSVP : ENABLED
getdan Fri, 03/02/2007 - 13:30
The auto-config command does not work in the 2811 router.
