Reliable Static routing issues
Feb 26th, 2007
Hi there, I have implemented Reliable static routing using 2 Cisco 1760 routers with WIC Enet cards with one Enet interface being the Primary interface and the other the secondary interface. The primary interface is a fibre link while the secondary interface is a Satellite connection. The issues I'm experiencing right now is that I'm experiencing high packet loss on the primary interface, apart from that the return times I'm getting seem to look funny i.e 350 ms on the primary interface which is a fibre link. Averagely 16ms is the normal RTT on the fibre link while 530 ms is the normal RTT on the Secondary interface. I realise that it could be a physical layer problem. Also could it be an IOS issue? I'm using
12.4(12) which is still LD. I just wanna make sure that my configurations are correct. They are listed below
ip sla monitor 1
type echo protocol ipIcmpEcho 150.150.150.1
timeout 10000
threshold 7
frequency 30
ip sla monitor schedule 1 life forever start-time now
track 123 rtr 1 reachability
delay down 60
interface Ethernet0/0
description Primary link
ip address 10.0.0.1 255.255.255.248
interface Ethernet1/0
ip address 172.16.12.1 255.255.255.248
ip access-group 120 in
full-duplex
ip local policy route-map MYMAP
access-list 101 permit icmp any host 150.150.150.1 echo
access-list 120 deny icmp host 150.150.150.1 any
access-list 120 permit ip any any
route-map MYMAP permit 10
match ip address 101
set ip next-hop 10.0.0.2
set interface Null0 Ethernet1/0
