WPA-PSK lost...
Answered Question
Feb 26th, 2007
I have several Aironet 1300's connected via WPA-PSK. One of them just went down (non-root) and I don't know the WPA-PSK. From the 4 that are still working I have the encrypted hash from the configs. Is there a way that I can crack one of these to acquire the key? I am talking about the key from the line that says:
wpa-psk ascii 7 XXXXX....
TIA for your comments.
Correct Answer by rtanner about 9 years 7 months ago
I just ran the encrypted password from
wpa-psk ascii 7 11584B5643475D5B5C737B
( ref: http://www.cisco.com/en/US/products/ps5853/products_configuration_guide_chapter09186a008067e9eb.html )
through the type 7 encrypted password decoder from Boson
http://www.boson.com/FreeUtilities.html
and it returned a "proper" value ...
so try this.
hth,
Ross
Overall Rating: 5 (1 ratings)
csannedhi Mon, 02/26/2007 - 19:48
Have you tried to load the configuration from one of the up AP on the down AP? May be this will work...good luck.
I don't know what hash function Cisco uses (MD5, SHA-1, etc.) but hash functions are mostly one-way, meaning you can not get the passphrase from the hash.
snickered Fri, 03/02/2007 - 18:11
Thanks partner. Worked like a charm. Now my building is back up.
